Caporegime
 - 18 Sep 2009
 - Dormanstown.
Got 8.1 back on the Laptop, but Modern UI hasn't sycned like my PC and Surface.
			For those wanting a clean install
check this link. Seems to work a treat.
http://www.eightforums.com/installation-setup/33164-how-download-windows-8-1-iso.html
that works.
but I don't think u can install this 8.1 normally with a 8 key. it's only good for refreshing.
Are you saying that once it's installed it won't allow activation, or that during install it won't accept the key?
At install it rejects the key as invalid.
u could use a blacklisted 8.1 key to install it then change the key to your 8 key within windows to activate.
Might have to try that. So the problem is just getting through the install and what key to use. Once windows is up and running it should authenticate with no problems using the old Windows 8 serial.
that what I thought has it's a upgrade key..
u could use a blacklisted 8.1 key to install it then change the key to your 8 key within windows.
Bit odd that you are forced to set up a Windows Account to continue the install. My wife uses a local account on her laptop, had to pull the network cable out during install and then it let me continue without having to use a Windows account.
Is it me or are 90% of the apps in the store rather rubbish and not worth installing? even if they are for free. Just a lot of rubbish to wade through.
I've never really understood why there was such a big fuss tbh... *shrug*
unplugged the mouse ,still hangs,just looked on Steelseries site and the drivers for 8.1 kill it and the drivers for 8 do not work on 8.1 they say at Steelseries,
been reading more,it is the Steelseries drivers ,keyboard and mouse,headsets not working right in win 8.1 also they are stopping win 8 from updating to win 8.1 and theres no fix yet
