Designed to run at 95c?
So it will be super stable at lower temps? Is that their goal?
95C target temp? I'm not saying nuffin![]()
Biggest thing that got me there was the fact that he said the gpus were designed to run at 95c... what does this mean for us!?
I have a quote from Thracks (pm from another forum which i can repost if needed) telling me the 7970 was designed to run at 90c so i wouldn't read too much into it. What hes saying is its fine operating up to that temp and will not throttle. Its likely going to reach that temp if you keep it in quiet mode. (40% fan speed) Of course you can increase the fan speed a little if needed to bring the temp down.
Perhaps that just changes the fan profile and increases the boost limit?
Really though, has there ever been a GPU designed to run at that temp? Thought most would be struggling with stability at 90+
The other interesting thing is the UBER switchPerhaps that just changes the fan profile and increases the boost limit?
Someone mentioned a second bios at one point...
Now looking at those images and claims of identical systems except for GPU's...BS
You can't get a stock cooler for a 3960X CPU.
-The AMD rep said he saw the rumors about the pricing online and the most widely accepted prices are ''completely wrong''.
Exactly. I bet it (second bios) also increases the voltage limit and TDP limit of the card. Titan mode, if you will.
Who wants to bet against me?![]()
lots chips are safe up to that point tho, it doesnt mean we want something that hot in our system, if its normal to run that hot u might aswell put a teabag in ur water res ><
safe/usual not the same ><
