if u wanted that then why did you buy a win 8 upgrade license?
This is what I'm saying - why does Microsoft insist on having an upgrade licence? Apple don't. You just get one version which installs the operating system. That's it.
The start screen is the correct resolution 2560x1440 (running a single screen on display port), however when I go to the desktop its seems to be be running at a different resolution, text is bigger and also icons as well, object desktop seems to be fuzzy and not crisp either.
Haven't tried it. I just want to wipe my drive and install 8.1 cleanly without fannying about reinstalling Windows 8, applying updates and then installing 8.1 from the store. If there was just one version which you could download as an ISO without requiring a previous version or having Basic, Pro, WMC versions, etc. it would be a helluva lot easier.
Change the display scaling back to 100%, 8.1 has an auto scaling option which is supposed to help if you have a small screen like a 10" with a high res like 1920x1080.
Personalize > Display > Check box that says "Let me choose one scaling level for all my displays"
•You might be asked to insert discs or recovery media that came with your PC. Check the info that came with your PC to see if your PC manufacturer provided these discs or media. In some cases, you might have created them when you first set up your PC.
•If you upgraded your PC from Windows 8 to Windows 8.1 and your PC has a Windows 8 recovery partition, resetting your PC will restore Windows 8. You’ll need to upgrade to Windows 8.1 after the reset has finished.
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc
Anyone have issue with Live tiles not working since updating to 8.1?
See image, they is now a little down arrow on them?
I assume, maybe incorrectly, that the "down arrow" indicates there's an update available for that app?!?
If I right click I dont even get option no more for live tile.I think down arrow means ready to download. click the title to start downloading
Nope app just opens normally.. I dont have no live tile feature, it was working yesterday.
I just fixed the news one by removing it and re-installing it so that means, it wants me to re-download them all lol
Think i'll wait for them to get patched.
I have just got Win 8 installed and am downloading 8.1 through the Windows Store. It's taking its' sweet time.
Only 50% of that bar is for download, and depending on the speed of your hard drive you might be waiting a lot longer (it took at least three hours to complete on my laptop, but it took my fathers computer around an hour less as it has a faster hard drive).
SSD so the install should be fast, hopefully.
