- 5 Sep 2011
- Surrey
I know, just means no present for the sister in law this year that's all
That would mean a night out for me and change. Damn it, no beer in place of smooth gaming![]()
Gsync now seems more impressive now that I understand it removes input lag.
Does it out weigh the advantages of mantle? Nvidia also have the advantage of physx, I'm not sure what to do now.
Don't lie - you're too old to go out.
You mean this one.
http://www.neowin.net/news/nvidia-announces-g-sync-to-help-make-pc-monitors-better
I have no faith in G-SYNC after reading this.
Games that NVIDIA discovers that have trouble with G-SYNC will be disabled by default in our driver.
Pointless having G-SYNC then.
You mean this one.
Q: Does NVIDIA G-SYNC work for all games?
A: NVIDIA G-SYNC works with all games. However, we have found some games that do not behave well and for those games we recommend that users take advantage of our control panel’s ability to disable G-SYNC per game. Games that NVIDIA discovers that have trouble with G-SYNC will be disabled by default in our driver.
Hm, I wasn't really comparing them like for like
I was just saying both are unique advantages. But, Matt has just pointed out that gsync doesn't remove input lag which was the main appeal for me as I play a lot of fps games![]()
Matt, read the page on geforce.com, it clearly says "eliminates input lag"
The company says that testing G-SYNC with pro gamers has resulted in those players dominating others without the module inside their monitors, thanks to nearly no visible lag in playing PC games.
On Friday NVIDIA announced G-Sync, and considering the little details available out there I wanted to write a quick follow-up on this new technology, as it really is a big announcement - a really big thing actually. NVIDIA G-SYNC is a solution that pretty much eliminates screen tearing, VSync input lag, and stutter. You need a G-SYNC module into monitors, allowing G-SYNC to synchronize the monitor to the output of the GPU.
Because low end gpu's spend more of their time down at lower fps. If your fps is not dropping below the refresh rate then there is no problem with smoothness. The only problem you might have, depending on the monitor is input latency. There are already ways past that though or to at least severely limit its effect.
