Assuming the rads are of decent quality/performance, I see no reason why 360/240 wouldn't handle a CPU and a 290 considering that plenty of people have been using the same rad configuration to cool OC'd CPU + Dual GPU's (6XX/79XX etc) for a while now with great results![]()
Love that build.
It's almost as cool as the one that cannot be mentioned![]()
I think I need to start benching at 4 am
Unless I read this incorrectly I cant believe so many people where horrified about Jbod having a 290x and a cpu under load with the hot 290x @ 48 degrees c where with the stock fan it would be 95 degrees!!
Good stuff. What core temp/clock/fan speed?
Nvidia having massively lowered the price of the GTX770 (one of the pre-Oced versions I am looking at cost 330€ 2 days ago and is not at 280€), makes me rethink the r290x.
Instead of the r290x, i will probably get 2 sli GTX 770 at a slightly higher price (a total of 560€ for 2 770s vs. roudabout 550€ for the r290x with bf4)
From what I heard, SLI is quite solid nowadays with microstuttering a thing of the past, but would anyone recommend against this setup? Performance will be significantly better on the SLI 770s
I have a X79 MB so I could fully use 2x 16 lanes for each card.
