@Mrk Do you have a link to your black background with the android figure on? pretty sure you said you took the photo yourself???
Ive gone back 100+ pages but cant for the life of me find it. Did see it a while back......Dont suppose you have a size to fit the res of the note 3 do you ?
Many thanks
Not sure which photo one you mean, is it the black wood texture one or Android green figure?
Yeah it's the black background with grey outline of the Android figure.
Think you took the picture from a case? Maybe totally wrong on that bit though.
really like this. Can you detail how you pieced it together? Specifically, i'd love to know how you got the call, sms counters at the bottom
Ah yes, this one?
I didn't really save it any higher res but it should be fine on the 1080p screen.
... Thanks very muchYou wishNot a massive change!, just a Nexus 5 wallpaper on my Nexus 5![]()
