*R9 290X Prolimatech MK-26 Fitting Guide*
31 Jul 2004
Yeah it's ok to work with, I'm only used to Artic Silver though which seems more fluid. I found this PK-3 does dry out quickly. I tried the plastic bag method to spread it at first but after a few wipes it just all went clumpy and stuck to the plastic, so I then used a credit card which worked ok.
Because the die is oblong I don't think that just using a small blob in the middle would spread correctly so I used a combination of both methods.
I never thought about using the backplate that came with the 290x but I think the screwholes might be too small - might give it a go later to let you know as I've gotta take it apart again anyway lol
Must admit I only use artic silver which is lovely to use, personally I would not use anything that "dries out" all these joints are live and constantly fretting so need to be lubricated as such ;)
OP
15 Oct 2013
Died out is perhaps the wrong wording, it just went abit clumpy. I think this might have been just the top of the tube, after i got past the top layer it was much better if I remember rightly.
awesome pictures, is that a 3 or 4 slot cooler?
It is 4 slot with the fans I think
OP
15 Oct 2013
@ Uncle Petey
Just had a thought. In your post here:
http://forums.overclockers.co.uk/showpost.php?p=23924445&postcount=830
It looks like you have applied your Akasa thermal tape the other way round to how I applied mine. I applied mine by peeling the yellow side off and sticking it to heatsink, whereas it looks like in your pic you have peeled the yellow side off and applied it to the chip. Do you think this could make a difference? The Akasa installation guide is less than clear. I'm thinking if the Akasa tape is designed to work one way then applying it upside down will not cool the chips properly... I hope this isn't the case as I will have to reapply the whole lot :(
OP
15 Oct 2013
I don't think it matters mate :) That just happened to be the way I did it.
I hope not, just got me thinking and worrying lol. If it does matter, then the instructions are useless!:
1.Remove yellow protective liner from one side and apply to device using moderate pressure.
2.Remove orange protective cover from the other side and carefully position the device in place using moderate pressure
In both steps 'device' could refer to chip or heatsink! Anyway, hopefully it makes no odds.
Just had confirmation of my Scythe's due to be turning up at 4:30 today, so if those and reapplying the vrm sink make no difference to the OC problem then I'm just gonna crack on and enjoy BF4 at stock clocks lol!
OP
15 Oct 2013
OK installed GPU-Z and got my VRM temps:
Everything stock @ idle:
Temp 1: 25
Temp 2: 29
Load (heaven 4 extreme)
Temp 1: Immediately up to 41 and then steady climb to 83 degrees where it settled for a while so I cranked up power target to +50, immediately after pressing apply I saw artefacts and the driver crashed. GPU-z log showed it got to 84 degrees and Temp 2 got to 58. The last 2 entries in the log show the power output going from 177W to 196W at which point the log stops because it crashed.
So you think this is pointing towards a VRM cooling problem? Temp 2 looks ok I guess, not sure where each temp is reading from though.
Anyone out there with the stock blower can you read the vrm temps under load for me?
23 Oct 2013
Temp 1: 25
Temp 2: 29
I am at work at the moment but i will get the new gpu-z tonight and check the temps on stock if no one beats me to it :)
22 Jul 2012
London
I think that definitely points to a VRM cooling issue.
Wait and see what the GT's can do about it and failing that, break out the thermal glue my friend :)
How did you get on with fanxpert btw?
OP
15 Oct 2013
Yeah will do. I haven't tried fanxpert yet, gonna hook the fans up to my fan controller first then see from there - thanks for sending it over though :)
I had another look at the card at lunchtime and it does look like the Alpenfohn beast vrm cooler will actually fit, just, so if I'm going down the thermal glue route I will use that for sure!
31 Oct 2013
thanks for this wonderfully informative thread, I have found it quite helpful.
One question I have is whether it is possible to find a those Alpenfohn coolers in the U.S.? Or if there is an alternative kit out there that would work...I say this because my R9 290X is scheduled to arrive today and I am thinking international shipping would take quite a while to ship out the VRAM coolers.
Thanks!
OP
15 Oct 2013
Well the reinstall and reseat of vrm sinks and the new scythes went well and my temps are certainly reduced. Getting 26 core temp idle and around 22 for both the vrms. However I do seem to still have a major issue and it seems to have got worse since this morning. I fired up heaven to test the vrm temps and they look good, rising slowly through to about 50 degrees, core was at about 60 and then I get loads of artefacts and either the driver crashes or pc reboots. This is after less than 1 min of running, same in valley.
Bugger bugger and bugger is all I can say!
I just reset my mobo bios and did fresh reinstall of windows 8.1 and still same issue. Didnt even open ccc to change any settings. Just crashes at stock clocks and voltages although temps are very good.
I'm at a loss now so having a few beers and chilling with the girlfriend lol.
22 Jul 2012
London
:mad: Seems like the cooler you make it, the worse it gets...
I'm baffled tbh, so I'll just grasp at straws for the moment.
- Is there any noticeable flex in the pcb?
- Is there anything that could possibly be shorting? (It's an unlikely long shot, but something kind of similar happened with the Peter fan bracket on mine when it was in a certain position.)
- Are the top screws overtightened?
That's all I can think of right now...
OP
15 Oct 2013
Thanks!
You actually get everything you need in the Prolimatech kit, its just the Alpenfohn ones are larger with more fins and therefore more surface area. As long as you have good fans and good case cooling you should be fine with just the Prolimatech kit.
In answer to your questions, yes there is some board flex, certainly noticeabale but doesnt look like it would cause an issue of this kind.
The fan brackets are installled centrally on the 2 main parts of the heatsink and are definitely not touching anythng else so I cant see how they are shorting anything.
I have tightened the screws more than last time, they are about as tight as they will go, but didnt use great force - could this really cause this sort of issue bearing in mind the temps are very good? :confused:
Thanks for your ongoing help!
22 Jul 2012
London
Glad to help if I can :)
Pcb flex could cause issues. Just trying to rule out certain things really.
I wasn't suggesting the fan brackets on yours are the issue. I was just wondering if there's anything that could possibly be making contact with something it shouldn't.
In my case, the PCI fan bracket could cause it to crash and restart if it was mounted tight up against the main heatsink, and it wouldn't do it until the card was under load for some reason.
Overtightening screws could damage the chip/socket or cause issues. The same applies to cpu coolers and cpu/gpu waterblocks.
If this can't be resolved with a bit of tinkering, I'd regretfully suggest restoring the card to stock and seeing how it does there. Hopefully there's no permanent issue caused by any of this.
@gateh0use
The Alpenfohn Peter is known as the Deepcool Dracula in the U.S. I don't know if they sell the heatsink kit separately over there, but that might help you find it :)
31 Jul 2004
It should not really reboot unless the CPU settings are flaky, unless some driver issue.
Artifacting is going to be the core or memory (if it does it quickly I would guess the memory), saw you had Elpida, not the best
If the thing will not run underclocked you have a hardware problem, how easy did the factory cooler lift off the memory chips ?
Try running the Pc on it's side to alleviate some of the weight from the card and slot before you go back to the original cooler.
OP
15 Oct 2013
Ok, it's a new day and more tinkering has been done. Touching every bit of wood I can see, I think, hope, pray that the issue is now resolved!
I'm not gonna get too excited just yet but here is the situation:
Woke up, remembered my 290x could be broken, heart sank of course (especially as I had planned a big BF4 lan party at my house today :()
Went downstairs, flipped the case on it's side to alleviate the flex, booted up and ran valley in 720p windowed mode - no crash after a few minutes. Got excited that the issue was resolved, tried again at 1080p fullscreen, artefacts after 30 secs, black screen 2 seconds later. Had to hard reset and got bios post code relating to no vga issue (along with red light next to the card) which incidentally has been happening with these crashes over the past day. Force power off, turn on, posts fine and boots to windows.
Checked the GPU-z temps at time of crash and they are now astonishingly good, 55 degrees core and 59 degrees vrm. So naturally I assumed I had a hardware issue and RMA'ing this card now will be less than simple without being rather creative :p
So I ran the same tests again above, crashed again after less than 1 min. Now I felt like giving up.
Took the card out and took the fans off and the 4 brackets. Unscrewed the 4 backplate screws by a few turns and then tightened them back up by hand, until gentle pressure wouldn't go any further (no screwdriver this time).
Instead of clipping the fans back on I just rested them at an angle against the card once installed in the case. Boooted back up, ran valley fullscreen, ultra, 1080p. NO CRASH after 3 mins+, temps excellent (although slightly higher as the fans aren't mounted properly).
Im still running it at 1080p windowed mode whilst writing this and have not seen a single artefact YET (10 mins or so now). Am now of course feeling quite excited again that the day might be saved!
So I think it is most likely that the screws were too tight, but it could equally have been the fan clips so to be sure I am going to cable tie them on I think. I knew these things are sensitive but I now appreciate just how sensitive they are. I've always tightened my CPU blocks with a screwdriver relatively tight and never had a problem, but I guess CPU's have a lid, whereas on this I was screwing down onto the die itself.
Valley is still running behind my browser btw, core at 57 and vrm at 65 :D
Thankyou so much to all you guys for expert help, I've never been an active forum member before (as you can see from my post count), and I'm now quite addicted! Next build I will be doing a watercooling rig as I have been running on air since my first build in 2003 so I'd like to learn the ins and outs of it all.
I will certainly be updating the fitting guide with all these caveats and warnings about what to look out for, once I am sure I am stable. I'm not even gonna touch the clocks or voltages yet - if I get through a day of BF4 gaming then I'll be happy and will come back to overclocking later on. I am at least fairly sure I don't have a hardware issue, so if these problems continue I will reapply the stock blower with new paste and pads.
Essay over :)
**UPDATE**
Going well peeps, got through a run of 3DMark11 with no issues at all. Running valley again with power target at +50, 10% overclock on core and mem (I swear I said I wasn't going to touch the clocks?!) and no issues at all. Happy bunny so far :) Am kind of dreading removing the card again to fit the fans though...
