Glad to help if I can
Pcb flex could cause issues. Just trying to rule out certain things really.
I wasn't suggesting the fan brackets on yours are the issue. I was just wondering if there's anything that could possibly be making contact with something it shouldn't.
In my case, the PCI fan bracket could cause it to crash and restart if it was mounted tight up against the main heatsink, and it wouldn't do it until the card was under load for some reason.
Overtightening screws could damage the chip/socket or cause issues. The same applies to cpu coolers and cpu/gpu waterblocks.
It should not really reboot unless the CPU settings are flaky, unless some driver issue.
Artifacting is going to be the core or memory (if it does it quickly I would guess the memory), saw you had Elpida, not the best
If the thing will not run underclocked you have a hardware problem, how easy did the factory cooler lift off the memory chips ?
Try running the Pc on it's side to alleviate some of the weight from the card and slot before you go back to the original cooler.
Ok, it's a new day and more tinkering has been done. Touching every bit of wood I can see, I think, hope, pray that the issue is now resolved!
I'm not gonna get too excited just yet but here is the situation:
Woke up, remembered my 290x could be broken, heart sank of course (especially as I had planned a big BF4 lan party at my house today
Went downstairs, flipped the case on it's side to alleviate the flex, booted up and ran valley in 720p windowed mode - no crash after a few minutes. Got excited that the issue was resolved, tried again at 1080p fullscreen, artefacts after 30 secs, black screen 2 seconds later. Had to hard reset and got bios post code relating to no vga issue (along with red light next to the card) which incidentally has been happening with these crashes over the past day. Force power off, turn on, posts fine and boots to windows.
Checked the GPU-z temps at time of crash and they are now astonishingly good, 55 degrees core and 59 degrees vrm. So naturally I assumed I had a hardware issue and RMA'ing this card now will be less than simple without being rather creative
So I ran the same tests again above, crashed again after less than 1 min. Now I felt like giving up.
Took the card out and took the fans off and the 4 brackets. Unscrewed the 4 backplate screws by a few turns and then tightened them back up by hand, until gentle pressure wouldn't go any further (no screwdriver this time).
Instead of clipping the fans back on I just rested them at an angle against the card once installed in the case. Boooted back up, ran valley fullscreen, ultra, 1080p. NO CRASH after 3 mins+, temps excellent (although slightly higher as the fans aren't mounted properly).
Im still running it at 1080p windowed mode whilst writing this and have not seen a single artefact YET (10 mins or so now). Am now of course feeling quite excited again that the day might be saved!
So I think it is most likely that the screws were too tight, but it could equally have been the fan clips so to be sure I am going to cable tie them on I think. I knew these things are sensitive but I now appreciate just how sensitive they are. I've always tightened my CPU blocks with a screwdriver relatively tight and never had a problem, but I guess CPU's have a lid, whereas on this I was screwing down onto the die itself.
Valley is still running behind my browser btw, core at 57 and vrm at 65
Thankyou so much to all you guys for expert help, I've never been an active forum member before (as you can see from my post count), and I'm now quite addicted! Next build I will be doing a watercooling rig as I have been running on air since my first build in 2003 so I'd like to learn the ins and outs of it all.
I will certainly be updating the fitting guide with all these caveats and warnings about what to look out for, once I am sure I am stable. I'm not even gonna touch the clocks or voltages yet - if I get through a day of BF4 gaming then I'll be happy and will come back to overclocking later on. I am at least fairly sure I don't have a hardware issue, so if these problems continue I will reapply the stock blower with new paste and pads.
Essay over
**UPDATE**
Going well peeps, got through a run of 3DMark11 with no issues at all. Running valley again with power target at +50, 10% overclock on core and mem (I swear I said I wasn't going to touch the clocks?!) and no issues at all. Happy bunny so far
Am kind of dreading removing the card again to fit the fans though...
