What's the easiest way to return this completely to stock?
I used this toolkit in the past & it worked fine for me
http://forum.xda-developers.com/showthread.php?t=2015469
Think i'll just wait for the over the air release of it and then try Paranoid Android when they sort it! Not actually put a ROM on my N4 yet, been more than happy with stock!
Have they done anything with the (largely pointless) 2-finger pull down settings drawer?
OK thanks. Is the lock screen different? Last leak I saw the camera had a dedicated icon on the (pattern) lock screen. Have they still got the multiple lock screen widget placeholders and the camera viewfinder placeholder thing?
Mattey1 - When you install Nova - do you lose the transparency on the nav and status bar?
I'll give it a try now, I have been using the stock launcher!
Edit:- I can confirm that it does indeed lose the transparency same with apex too. Looks like launchers need an update!
Does the album art on the lockscreen only work with Google Music? Can it work with others like Poweramp?
Just tried installing the ASOP 4.4 ROM and it soft rocked my phone!!
