The Palmersport single seaters at Bedford have a system that tracks the cars position in relation to the track, if you cut a corner too much your engine power is cut for a couple of seconds.
The FIA could easily have the ability to control the cars remotely via the standardised ECUs and the existing systems in place for regulating KERS and DRS etc so a similar system could easily be implemented to ensure that anyone who goes 4 wheels off for any reason loses enough time that there's no benefit to doing it deliberately.
If there are concerns about false detection/safety/drivers not being in control of the car then an alternative would be that if you go 4 wheels off it is detected and a warning light is activated in the cockpit. The driver is then given a certain amount of time to find a safe point to press a button which will cause the car to reduce power (and flash the rain light to warn following cars of a slow vehicle) or they can appeal the decision which is then manually reviewed (with a drive through if you either don't comply or lose your appeal to prevent frivolous appeals)
