Are you setting a manual fan profile and if so what software you using?
Can you use MsI afterburner with non-MSI cards (I have a sapphire)
Yep you can.
What drivers are you all using. Quick test, I stuck everything on max settings for Max Payne, Crysis and both crashed to desktop. Literally just went black and disappeared. Wonder if it's the drivers as it wasn't a "program not responding" just vanished?! Rome total war seemed fine however..
Think I'm using 13.11 beta drivers
?Scrap that, hard reset in TW2, pc just turned off. PSU problems? or driver related? strange thing is that the PSU ran 2 x SLI 560ti's overclocked no problem and OC i5.
Currently i5 and 290 are running at stock
Any recommendations on a new PSU to replace mine, £100 ish? the money I saved on a 780 is now being used to buy a new PSU... grrr haha
It would probably run on a decent 500W to 550W PSU TBH. The SteamBox is using a 450W SFF PSU AFAIK with a Geforce Titan.
Strange, I have a 650 watt OCZ PSU. Stock i5, couple hardrive and the 290 at stock, but getting hard resets in anything 3D...
Interesting, my card has been hard resetting my system too.
Now I'm getting a few BSOD's![]()
Can someone give me a bios?
Just got my card!! very happy. Yeah its a little loud but not as bad as people have been making out. It is less so than the hd 7990.
I have overclocked a little and think i have it stable at 1125 on the CC and 1450 on the MC with stock volts and stock bios. Was hoping for a little more but this is fine i guess.
I flashed the BIOS with the ASUS one, everything looked to have worked but within afterburner i cant adjust it. Does anyone have any ideas as to what i may have done wrong?
any help would be great
