- 5 Sep 2011
- Surrey
I read it as two 7990s! Decent 850W should be adequate but would go with 1000W for headroom.
Does your gpu usage jump like mine?
The thing is that was what I found strange. I would use 1050/1500 and get like 85% usage, go 1100/1500 and it would jump down to like 60% (Crysis 3). Could not figure out what that was. Thought I had a card with some lower quality components, so it just could not hold it's own.
Though the strange thing that I get the card full use when I just benchmark at 1100/1575
I just stopped trying in Bf4, just having a slight overclock of 1050/1500.
Are you sure it's not just the game Matt? I would have thought BF4 would be pushing it harder.
Hadn't realise you'd bought one of these![]()
Mine seems ok i think at 1.230v 1100/1575 in bf4. I didn't notice the problem. However i get it even at stock in sleeping dogs. I was using some psu braided cables (though not on the pci-e area) so i will try without those and see if it makes a difference.
I used a hack to allow the power line to be increased. I wanted to make sure the card wasn't throttling.
Cool cheers! Are there any real diffs between software vs hardware hacking?
I know nothing about hardware hacking im afraid.
Guys what is the difference in temps between your gpu cores? Just playing some bf4 with vsync off and gpu1 was 10c hotter than gpu2. Normal or bad paste job on one core?
Rather I mean BIOS flashing ... apologies!
Hack - http://forums.overclockers.co.uk/showthread.php?t=18509458
I downloaded gputweak last night and that allowed memory voltage tweaking, though im not sure if it actually works or not.
