Plusnet Discussion Thread
After waiting a week while PN carried out tests I got a phonecall from them and was asked my to run a Tap3 test. They managed to book an engineer for the next day which was good. He tested the line but found no faults on the line. It seems either someone did a reset or running the Tap3 test did something as I have some of my DL speed back. It's not as much as it was before and my ping is still higher. Engineer said to give it 5 days to see what happens.
Hi,
It should be complete now from what I can tell. The order's showing as complete in BTw's provisioning systems and I'm able to run tests on the line (needless to say, it's not connected to us at present).
Regards,
I presume some people have been using the top cashback deal with plusnet. I work it out as an average of 12.55 over the lengtho f the 18month contract for the unlimited fibre. Does that sound right? If so that is pretty tempting.
I have never used topcashback before, can anyone confirm that this deal will actually work.
I had been looking at BT, which is obviously a fair bit more expensive than plusnet. Is there anything I should be warned about with regards to plusnet? is the router oK?
Hi,
Regards,
All the updates on my tickets were wrong, my order hasn't gone through and my mac code is expired now. Plusnet have asked me to obtain new mac code now. My original order was placed on 25th October I think, communication has been good from plusnet but results are very poor so far :(. Seriouly thinking about staying with BT.
I can understand the reason for the confusion. The order is completed and closed off in BTw's provisioning systems so we had no reason to believe it was anything but. Turns out that no physical work has been done to move your service though.
Somewhat out of our control, however I'm sorry we let you down.
Looks like you've got Chris on the case now who I believe will be looking to expedite the new order due to failings caused by our supplier.
Make sure you nudge somebody when you are up and running so that we can adjust your billing.
Best regards,
