do you think my ocz zx1000 will be able to cope.
Well if it doesn't it should still be in warran- oh.
Sorry had to
Welcome to the club!![]()
Well, I'm now a 7990 owner![]()
ThanksIt will be here on Monday.
I feel stupid doing another sidegrade, but I have upgraditis![]()
I've wanted one since they came outLol you folded quickly. Make sure you flash the bios.![]()
I've wanted one since they came outAnd hey, it's Christmas
Is ATIFlash the best way?
What temps are people getting with these cards?
I have two in my HAF XB case with the side and top off in 3DMark one is hitting 91c (max) - is this acceptable? Something like 1.2v @ 1150Mhz.
I may have to do what everyone else is doing and under volt at stock (but it feels wrong not to be overclocking).
That or water cool them... Which is tempting based on the temps I've seen so far :/
Also, my ASIC is between 61 - 67% (varies across the 4 GPU's) via GPU-Z is it higher the better? Is this rating legit or just something GPU-Z randomly calculates based on some magic algorithm ?
This way is the best way. Other ways are possible but i can't help with. But yes, atiflash is the preferred method.
I'm running mine in a HAF 932 case. Matt's BIOS (Cheers Matt). Undervolted to 1.120 Afterburner.
Asic 62.2 64.1 . Just played over an hour of BF4. 1920x1080 Ultra 4x MSAA
Max temps 60c and 58c. Fan speeds 62% and 56%
I haven't overclocked my card though. Running stock BIOS settings max temp was about 71c.
On stock settings would it be safe to drop voltage to 1130?
Blimey, thats superb. Mind sharing some pics of your case setup mate? Always looking for ways i can improve mine.
EDIT
Did you have vsync on or anything?
Anyone running a 7990 with a 144/120Hz screen?
[email protected]
7990@100/1500
Couple of hours of BF4, vsync off, 1440p Ultra preset +x4AA. Fpsd ranging from 60-130+ Using my custom bios. Stock voltage lowered from 1.2v to 1.130v. Case fans on low rpm, H100i on intake on low rpm. 85c max temp on both gpu's. If i turned my case fans up a bit temps would be 3-5c lower. If i turned the gpu fan up temps would be 10-15c lower but im trying to make things as quiet as possible now, just as a personal test. My previous 7950's had to be at 100% fan speed to get even close to this level of performance. For the record Auto fan is around 40-50% at these temps. It starts to crank up a bit once you go past 85-90c.
http://i.imgur.com/h0xivxu.jpg[/IMG[/QUOTE]
Your bios certainly keeps it cool and quiet, which is also what i am going for.
Cooling would be better for me if my cpu heatsink didn't get in the way of my side case fan.
