*** The 2013 Gym Rats Thread ***
Delvis, really can't see why the bar should slip from your hands in squats! Can understand chalking your back as ice says, but only under HEAVY loads. Haven't felt the need to do it yet and I'm on ~140 working sets.
It doesn't slip FROM my hands, I grip the bar and pull it down so sometimes me hands slip inwards. Doesn't help I use the thumb over the bar grip.
My greatest discovery was chalking my hands for OHPing, much easier when your sweaty hands aren't trying to escape to the ends of the bar.
Because gripping the bar as you would with deadlifts makes my shoulders hurt due to poor internal rotation (or external, or both), it also been known to hurt my wrists due to bending them back.
I'm working on it basically, it's just ridiculously painful :p
Chalk is beautiful!
On bench, squats etc I use a bit of chalk. On deadlifts I practically wear it as an outfit. Makes me feel more 'badass' and helps with grip. I reckon the former reason is worth a kg or two on its own ;)
I use chalk on practically everything
Can confirm, chalked for curls. Srs.
Chalking your back for squats definitely helps the bar feel more connected across your back. It shouldn't really be necessary for lighter weights though.
I give the backs of my shoulders/rear delts a covering as it stops any slip when sweaty. Front squats I pretty much cover myself in it.
I chalk my angus crack as an anti peppering measure.
Still IN.
Thumb over the bar? Why? Not even I'm stupid enough to try that :D
Bru pls. I suicide gripped my 140KG bench attempt, twice. /livedangerously. (I don't anymore for the record).
Guys i need some info please.
I have been going to the gym for around 2 months now, whilst i am seeing improvements elsewhere (fitness and some definition starting) i don't seem to be able to move past what im currently benching.
ATM i am 11st and 5ft 8, my BP atm including the bar is 80kg, and i can't seem to move past it.
I reckon it's your diet.
But what's your training routine?
I go to the gym mon-wed-fri, start off with around 15 minutes on the treadmill, i then go onto the bench press, try and aim for 6-8 reps and doing 5 sets, is this not enough/too much?.
Then after BP do dumbbells, work my back,chest and arms on the multi gym, finish off with cross trainer for 30 minutes, at the gym for just under 2 hours.
Squats will increase your bench, srs.
Sounds like you need more structure and to address your diet.
I don't have the patience/time but someone else will be along shortly I'm sure :)
Identify where your rep is breaking down and fix it. I was constantly failing because my triceps were much weaker then my chest so I've been doing lots of work on them.
You are training bench, three times a week, for 6-8 reps, having started at the gym two months ago? :eek:
First off, 80kg bench for 6-8 reps is not bad at all. :)
Secondly, you a probably knackered as a result of the beginnings of overtraining and thirdly, your previously mentioned crud diet.
Two months in, you can still make beautiful gains training once a week, giving you enough time to recover. Also, if you hit a plateau, you have a couple of options with a specific lift: drop the reps and up the weight, or drop the weight and up the reps.
My personal preference is to drop the weight and up the reps.
Also, as already identified... EAT MOAR!
I saw a fat guy in the gym yesterday he couldn't do dumbbell curls properly and looked like it was his first day at the gym.. Yet he jumped (and spent the rest of his without) in the bench rack and pushed 100... Pfth.. I'm working my bum here at 80kg.. Some people are simply stronger at certain things, my benches let me down but I'm cool with it I'll get to that magic one hundred sooner or later!!
I have been at the gym before so I'm used to working out :)
80kg for my first set I manage 8 reps, sets 2 3 and 4 I manage around 5, then set 5 I try and do as many as I can. I take 20 seconds break in between each set, that too long?
I'm trying to eat as much as I can but because I'm on 6-2 shifts and 2-10, I find it hard to stick to my food plan.
When im on 6-2, I have a 10 minute break at 8am, I'll have 2 bananas and coffee, then my next break is 11.30, too early to be eating things like chicken etc as I don't have the stomach for it that early.
Your workout is dreadful, benching three times a week? What is this somolov Jr bandwagon?
You need to pay attention to other body parts, and more structure. Something like starting strength is a good place to start.
