*** Official AMD 7990 Owners Thread ***
Hi Ltmatt,
Just received a msi 7990 today, along with a corsair rm 850, I'm well excited to get it up and running.
Coming from a single 7970, which had your ab fan profile running for god knows how long. =)
Would love to flash your bios, but haven't even turned the system on yet, if I install the latest beta's which bios should I go for, would it help if I post what mine has?
I respect you for the effort you put into helping people.
Cheers.
Received mine today, came with a pair of 6pin to 8pin PCI-E power adapters, I understand that the probably are a couple of PSU's out there which pre-date the 8pin PCI-E standard which are quite capable of running a HD7990 but still I can't help that feel including them with the card is a bit of a recipe for disaster, power without responsibility and all :P
Hi Ltmatt,
Cheers.
Use this bios.
http://forums.overclockers.co.uk/showthread.php?p=25335363#post25335363
What clocks, voltage settings, fan speed, case air flow setup are you using? More details plox.
Standard clocks and voltage at the moment. CPU is i7 2700k @ 4.4Ghz, cooled by Corsair H100i. I have a couple of scythe gentle typhoons @ less than 1000rpm blowing over the card from the front and 1 blowing out the back of the case.
Will do. Thanks.
Just put my new graphics card in and can hear a buzzing when i move windows around! Wtf!
It's coming from the top of the card, not the psu.
Coil whine - its been well documented on these forums. Apparently it will bed in after long benchmarks runs etc.
I have the same with my 7990. In my case, with vsync on its a crackling/buzzing noise. If I take vsync off it becomes more of a high pitched squeal.
I tested with Ati tool, usual coil whine but really loud, louder than my 7970!
I wonder if the Corsair Rx 850 i received today is to blame? The psu itself is silent.
Is everybody hearing this crackling/buzzing noise on the desktop in Idle whilst moving windows around?
Even highlighting my text here in the forum produces the buzzing!
I booted into safe mode to run DDU, in safe mode there was no buzzing on the desktop, as you know its running at a much lower resolution.
I have my MSI 7990 here ( going to compare it against my GTX 690 ) so I will let ya know how bad the coil whine is. I will flash it and install it later. Depending on what happens I may keep it or not. ( Also depends if I take Litecoin mining up )
I dont mind if the card squeals, hopefully i can tame that with using vsync/cap fps.
But as I listen to music using Open headphones, I dont want to hear buzzing whilst browsing the web.
Update, Gpu-z reports that the card in idle is at 150/300 (mem/gpu(, dragging a window around makes the clocks shoot up to 1000/1500.
Ahh sound wise - I use a 5.1 Onkyo amp with Mission speakers so it may or may not bother me........ Plus I have the PS4 and Xbox one / Wii U / Ps3 as well all attached so a lot of noise normally anyway. It all depends how bad it is.
Should be able to let ya know in a couple of hours.
Guys i pretty much solved my coil whine by using two different pci-e cables plugged into the card rather than one cable with two 4pins on it.
Just a silly little question for Matt,
I have installed Beta Drivers / MSI Afterburner as per your thread on checking crossfire is working.
BUT I do not have the Catalyst Crossfire section to check/tick.
But I can set Frame Pacing and when I right click on the tray and set the AMD Crossfire Status Icon (Where applicable). Does this mean it is working? Or am I being a complete **** and missed something really obvious. MSI Afterburner indicates GPU 2 isn't doing anything.
I am on Windows 7 if that is any help.
Yes a 7990 does not have the option for some reason. However you can still disable crossfire if needed by creating a CCC application profile for the game. :)
