81C is the highest temp my 7990 is working at in my Carbide 540. Quite pleased![]()
No it won't void warranty. Always use the latest beta drivers if you have more than one gpu.
Hi Ltmatt,
Just received a msi 7990 today, along with a corsair rm 850, I'm well excited to get it up and running.
Coming from a single 7970, which had your ab fan profile running for god knows how long. =)
Would love to flash your bios, but haven't even turned the system on yet, if I install the latest beta's which bios should I go for, would it help if I post what mine has?
I respect you for the effort you put into helping people.
Cheers.
What clocks, voltage settings, fan speed, case air flow setup are you using? More details plox.
Will do. Thanks.
Just put my new graphics card in and can hear a buzzing when i move windows around! Wtf!
It's coming from the top of the card, not the psu.
Not your usual squeal, more of a crackling/buzzing sound.
I have the same with my 7990. In my case, with vsync on its a crackling/buzzing noise. If I take vsync off it becomes more of a high pitched squeal.
I have my MSI 7990 here ( going to compare it against my GTX 690 ) so I will let ya know how bad the coil whine is. I will flash it and install it later. Depending on what happens I may keep it or not. ( Also depends if I take Litecoin mining up )
Just a silly little question for Matt,
I have installed Beta Drivers / MSI Afterburner as per your thread on checking crossfire is working.
BUT I do not have the Catalyst Crossfire section to check/tick.
But I can set Frame Pacing and when I right click on the tray and set the AMD Crossfire Status Icon (Where applicable). Does this mean it is working? Or am I being a complete **** and missed something really obvious. MSI Afterburner indicates GPU 2 isn't doing anything.
I am on Windows 7 if that is any help.
