No idea what I've done to make it look like this, something's broken somewhere. Does anyone else think it looks a little cel shaded in it's broken state?
Try installing the WATER mod in op and overwrite?
Have you followed the ini tweak instructions?
e.t.c![]()
It looks like you've installed an enb/sweetfx wrong.
Have you tried to install an ENB with mod manager instead of cut/pasting it into the skyrim folder?
or have you tried to install sweetfx over an enb without altering the enblocal.ini to have this..
[PROXY]
EnableProxyLibrary=true
InitProxyFunctions=true
ProxyLibrary=d3d9injFX.dll
you don't launch the game the usual way, you launch it via the new skse launcher icon on your desktop
I always seem to hit a wall with this game.
The more and more mods you add, the better the game becomes, but now I seem to have hit a point where it will CTD every 5 minutes.
ummm so i'm a bit daunted by the size of this thread and the amount of options.
Bought Skyrim recently via Steam sale. Never played it, RPG games are not my norm so what would simple mods would you recommend for someone new to the game?
I'd always recommend 5) SkyUI + Better Sorting + Categorized Favorites Menu - interface replacement for any new player!
One you get to grips of the game, you can then move onto the graphical updates( Just not the DLC high res )
Untick, deactive one mod at a time using nmm especially trom the last one and see if it CTD's![]()
Bloomin heck - More mods for me to install.
I spend more time messing with mods that playing this game![]()
If you're using a newer version then the FPS limiter moved from enbseries.ini to enblocal.ini
