just updated it a bit so refresh it mate.
Have done, thanks for letting me know.
Have you run a Occt Linpack AvX test, minimum One hour with these settings?
what you cooling it with ? and i have done aida64 extreme and unigine and 3dmark and vantage and run battlefield for an hour or so and get no problems at all, and i have my gpu ocd as well![]()
tried the bios and its very unstable on my machine so gone back to F1 for now, as even stock clocks i was having issues with blue screens etc. Where as with F1 the system is stable in that respect.
Bloody Audio device, Hope gigabyte get back to me soon.
Fingers crossed on the audio disappearing issues i have been plagued with.When you say power cable for your Dac is it a mains cable? If so it could possibly be your psu? It might be worth double checking all of your cables make sure they are all plugged in correctly.
Would say that windows boot up error is probably a corrupt windows file or possibly driver related?
Can you replicate it and instead of going into windows normal, try going into safemode, if it will boot straight into safemode when it would normally freeze up, then you gotta say its software related. If it freezes up trying to load safemode theres a good chance you will see what it freezes trying to load.
If I am reading it correct then, with the computer turned off and your DAC disconnected you dont get a noise, but when you turn it on your do although it still isn't connected?
If so then it could be your PSU putting noise on the mains, which isn't that likely tbh, but with electronics anything is possible.
Which bios are you running and do you have anything OC'd? Did you load defaults after you flashed, or when you installed it?
