Not sure which service is due
Yeah I get it I just don't see why you didn't get a car in the UK as opposed to sourcing one in a tiny pool in DEIt may sound a weird thing to do but I would say 95% of serving personnel over here drive UK cars. Tax free cars are bought into Germany then after a year or 2 taken back to the UK to be sold for basically the same price they were bought for. Some are kept for longer though and sold to other squaddies like mine.
Just not a lot of e46's around. Was looking at a 330ci but it had 20k more miles was 2 years older and £1k more expensive. He also wanted to keep it till the new year which we wanted a car before xmas.
[TW]Fox;25530414 said:It tells you when you start the engine what the next service due is.
Yeah I get it I just don't see why you didn't get a car in the UK as opposed to sourcing one in a tiny pool in DE![]()
Assuming it has been correctly reset. If its got ropey history its probably had an " inspection 2" From everywhere that's touched it and claims all it needs is an oil service
Think its a 16" space saver, can check later if you need to know exact sizes
Edit might be 17 to clear the discs....will have a look
Definitely not under the second plastic cover? That confused me for about a week after I got mine. You might find a single alloy with tyre is much the same cost as a space saver - worth checking
