Assassin's Creed IV- Black Flag
Back up your save games folder on this game.
I've just had a right runaround after Ubisoft support advised me to re-install the Uplay launcher, trying to fix my constant 'loading additional components' glitch. It basically also re-installed the game, loosing all my progress and game saves. Cloud save is no help, it's not turned on by Ubisoft on this game!
I've always stuck up for Ubisoft in the past but this has tested my patience.. :mad:
EDIT. Got a fix for this if anyone get's the same problem. Launch Uplay but don't launch the game from there. Find ACBFSP.exe (or MP) in Ubisoft Game Launcher and use that to launch the game. Bingo! No faffing about, straight in.
I had an issue where it would crash in the same spot every time. I tried everything and I think the problem was that Uplay didn't download all the files. I used the "Verify Files" option for the game, and thought uplay would download the missing ones. I had to click "Install" after Verifying and it downloaded some more, and now it is working fine.
Uplay is ****.
When I run this game I get like a blue flash every second or so. Happens from the moment the game goes fullscreen, even during the Ubisoft splash.
Any idea how to fix? Google turns up a blank.
Anyone experienced the game crashing at the
start of the Africa mission where you have to sink 5 ships?
Has crashed for me twice now
I'm experiencing crashing at the startup, every time. As soon as it hits the "This game is based on many faiths and beliefs...." etc, I get a AC4BFSP has stopped working error.
What can I do? I've tried redownloading and reinstalling several times :/
Did you try this?
Uplay is ****.
There is a mod I've seen somewhere that allows you to bypass the intro logos which may or may not help:-
In your "Assassins Creed IV Black Flag\videos" folder backup these files and there after delete them. Forcing the game to skip them:
abstergo_logo.bik
ac4bf_logo.bik
TWIMTBP.bik
ubi_logo.bik
abstergo_logo.bik
ac4bf_logo.bik
TWIMTBP.bik
ubi_logo.bik
It crashes on the screen before those T_T
I downloaded it 4 times, yet it wasn't downloading it all.
Will try
