My theory is that Nvidia are buying forum accounts and posting fake stories about blackscreens and DOA cards.
There's no other explanation!!!
reducing clock and then stable - highly suggests hardware fault not driver/software issue - surely?
if was driver related - the clock speed of the VRAM shouldn't make any difference
The plot thickens (posted this on the owners thread)
http://www.youtube.com/watch?v=G5jLzhAdjv8
I can reproduce the black screen crash on Unigine Heaven 4 at exactly the same points on Linux and windows O.o That type of predictability kind of indicates a driver error :/
I was rather annoyed at first when I couldn't overclocking memory much before getting black screen (I was lucky to at least have a card that's stable at stock clock I think), but after comparing bench results, I'm not so bothered by it anymore as it made like 1-2fps difference between 5000MHz and 6000MHz at 80fps range in the Sleeping Dogs bench...the different would be even less at sub 60fps and I doubt I would even notice the difference.I don't suppose anybody has actually got to the bottom of these black screen issues. They seem to be happening more and more often to me now, not in intensive gaming but when I'm playing DOTA or trying to watch a youtube video.
I just find it odd how 2-3 hours of BF4 will be fine and yet trying to watch a youtube video causes my PC to fall over.
I'm going to try running the memory at 4900MHz and see what happens, although I won't be happy if I have to run the card permanently down-clocked....
Stable for bench doesn't mean stable for games. Usually you find the stable overclock in bench such as Heaven, then for games you'd ideally knock around at least 50MHz off the core clock and 100MHz off the memory clock to give more headroom for stability.
That is what i have found, can you explain why that might be ?? why benches are diff to a game from a stability point of view ?
Cheers Spence
This problem havent improved with new drivers. Only workin solution is to start the pc once and shutdown and then start it again. What is strange is that it then works just fine whole day. Next im trying to keep the pc powered on night and see if it still works next day.Heres my notes of the black screen problem with 290X. My PC is powered down over night and when i start it for the first time it will black screen once within a hour. Then i power down and no problems after that. I think if i start the PC and then shutdown it when windows is loaded and start again im good without black screen. Other night i noticed when i black screened and was playing BF4 and talking with my friends in TeamSpeak3 when the black screen occured i was good for talkin to my friends even the black screen was present at the time. The catalyst beta 9.4 drivers were better and the delay of black screen increased but not gone.
https://www.youtube.com/watch?v=BoN5Pail678
A video I made before I put it in the box to get picked up for RMA, It happened after 20 seconds of BF4. It can happen that fast or it can happen after an hour. I picked up a 780 today so **** AMD
Forgot to say that was at 947/1250, if I drop it to 947/1150 it does not black screen but parts of my screen occasionally flicker black for a split second.
Have AMD commented on this yet?
I am yet to see an official comment on it yet, but they must be aware of the issue given the note in the latest drivers: "May resolve intermittent black screens or display loss observed on some AMD Radeon R9 290X and AMD Radeon R9 290 graphics cards"
MAY being the key word here...
