I'll be doing it on something soft for the first few haha.
It's not the act that is itself particularly unpleasant. It is how you will feel for a few days after.
(Edit - Moved from old thread).
GVT snip
I found 10x10 too brutal, and I love volume. GVT is better suited for those on special "assistance", in my opinion.
Hence why I favour AGVT over it. It's 10x5 (10 sets of 5 reps).
The key to (A)GVT is time under the bar, so the negative reps are crucial to do slowly.
I also don't bother with arms, but each to their own
I also wouldn't bother with "abs" specific workouts. There really isn't much need for it. Do more leg work instead.
Indeed, although I have always thought dropping the number of sets was an odd way to progress...But that doesn't mean anything other than I am easily confused.
I already predicted he funny walk for the following few days!. (I say funny walk, I mean working from homeIt's not the act that is itself particularly unpleasant. It is how you will feel for a few days after.![]()
Ay, thought so - it's an exercise I don't like skipping so wanted to pop it into something.I didn't spot lack of deadlifts. Shove them on a back day. CRUCIAL exercise.
4 sec negative for the larger lifts & 3 for the smaller ones from what I've read.I hope you are using the correct rep tempo's & eccentric phases young man.
Agreed.
GVT is humbling and more of a mental challenge than physical once you become accustomed to the rep tempo's. However GVT is really a strength endurance programme and offers not real progression, not for 10 weeks anyway.
AGVT would be better suited as FF suggests.
Sounds like a planPerhaps do it on day 4? Give you a bit of recovery time from legs or do it on Day 1.
Will do some further reading on AGVT, as currently on a short cut - undoing the festive damage & want to get back down to at least 15% BF before starting a bulking phase so a routine well suited to a minor deficit.
Well when I did the weights that they suggested it was a lot easier than I thought so I upped the weight to start with and went from there.Stronglifts is structured in a given manner to help new starters make both kinds of gains very effectively: looking at your spreadsheet, you started heavier than I would have expected for a newcomer which mean you may be missing that (ahem) stable base that drilling the lifting pattern helps, as well as the resulting numerous weeks of lifting sub-maximally before coming close to your actual max.
Secondly, your diet and sleeping patterns could be hindering you, too: not enough of either will slow your progress quite effectively.
What I am saying is: do Stronglifts properly if you're going to do it as it works a treat.![]()
Mobilise it, don't just let it heal in it's naff state.
Ah, don't get me wrong - I'm still active, I just can't do the fun things in the gym (squat, bench, dead, shoulder press etc)
It's not a serious injury, just hurts like a ******* when i engage muscles around my clavicle / rotator cuff.
Yep, it's the only acceptable time to train through pain!Question, would you train legs while still suffering from the last DOM's leg day? (was last Friday, first chance to train in a while so thought I'd make it legs).
The downside is the workout takes forever & normally I like to be in & out in about an hour of solid lifting - but the 10x10 takes so long with the proper times & rest periods I may need to switch to the 10x5 for time-keeping purposes.
