I certainly do have some flexibility problems when squatting, they don't get in the way of depth as I go as far as is possible, I do however sometimes end up with one of my shoulders hurting because of my width, I sometimes have to hold my arms quite narrow to be able to rack and unrack the bar without trapping my fingers.
Fair enough, I still want to see a video though, if only because I'm a perv <3
If your shoulders hurt from squatting, then it's very likely that you have tight pecs. There's plenty of material in the mobility thread to help you deal with this.
My lower back is also crap, like with dead lifts, I'm the opposite of most deads I see, I pull the bar up quickly until my lower back comes in to it and then it's a grind to lock out, whereas I see most people slow off the start of the pull and then when their lower back activates, they snap up straight.
You've described perfectly what happens for someone who lifts with a non-flat lower back. You're fast off the floor because rounding your back makes the bottom of the lift the strongest position, but you pay the price when it comes to lock out.
Your lower back muscles should be stabilising your trunk along with the rest of the muscles in your core, they should not be prime movers. Well, I guess that is slightly subjective, but the injury risk is significantly higher with a rounded lower back.
The parallol was in reference to the above, however I do think the term "parallel" itself does have connotations of the above situation where the femur is 90 degrees to the tibia.
I'm not critical of proper squatting, it's just I very rarely see it due to looking at the wrong feds as it seems.
This is a bit of a problem with "powerlifting" as a whole.
The powerlifting the counts is done in the IPF (International Powerlifting Federation - the international body) and it's national affiliates. In the here we have the GBPF, and in America it's the USAPL. This includes both equipped and classic lifting, although IMO classic is way cooler.
The irony is that most of the other terrible federations actually have the same rules about squat depth, but they just employ some very creative interpretation. White lights seem to be influenced by the celebrity of the lifter, and the weight on the bar. You are famously not allowed to film from the side in a lot of these federations, and they proclaim that "you can't judge depth from the front". Sooo...
haha not a bad effort. Bad perspective on this.
This is you at 75kg and 6 foot?
Do you have mass anywhere but your arms?
His screaming does my head in lol
To be fair, he's just won gold in the squat
