- 8 Sep 2009
- Swindon
gibbo the maximum memory mhz ab lets me go up to is 1625 how the hell you getting 6000 ?
1625 x 4 = 6500
The sapphire is crazy loud at 100%, not comfortable to sit next to at all![]()
Slightly off topic question here: does anyone know how to get MSI Afterburner OSD to work in BF4? It's working in every other game for, just no this one.
Cheers for the link mate
a solid 40 mins of BF4 and no black screens
Oh, and sweet sweet card![]()
Hi there
For anyone with a MSI 290 Gamer struggling to clock ram beyond 6000MHz try flashing a regular Asus 290 bios, none X as this is just an AMD bios, for some reason I can now get 6800MHz memory OC on the regular 290. Have MSI done something in the BIOS to hold the regular 290 back OC wise I wonder?
So not good ram OC, try it.
The AMD BIOS is also far better for undervolting too.
Maybe the 290X is similar, but I never tried it's stock BIOS as I flash all 290X always to the Asus 290X bios for extra voltage.![]()
One of my fans at 100% has starting to make an irritating crackling noise... is there anything I can do about it?
Also, something I discovered whilst making a video of it:
https://www.dropbox.com/s/dxzl0uqaq2w4ylc/20140116_071657.mp4
It only occurs when the system is standing up, but is fine when laying down.
Would this be a valid reason to RMA?
Sounds like something is catching the the fan? Is it the fan cable connected to the pcb? Maybe you can push it in yourself.
Thought so too, but I checked, definitely nothing in its way. Note that this at 100% fan speed. You can't hear it roughly below 70% fan speed
RMA it then. I'm guessing its something that will get worse, not better.
I've never had to RMA anything in my life. Would you mind explaining where do I start? I don't mind if you have to PM me.
If you got it through OcuK just put a post in the component technical support section of customer service at the top of the forum. Give Bailey a link to the video as well.
skins here for AB
http://event.msi.com/vga/afterburner/skin.htm
download and extract to ab folder and then skins then change in the options in ab
simples
also everyone using a 290 get the newest beta as already said!!!!
3.0.0 beta 18
right now
Do you have any evidence of this? Video reviews would suggest this is far from the case...?
