Ah, only thing I'm not doing is running BF4 in x86. i'll try that.Try this
http://download1.msi.com/files/downloads/uti_exe/vga/MSIAfterburnerSetup300Beta18.zip
uninstall afterburner and install the above one
what sort of temps are people getting with this card, got mine 2day and out of the box after 30mins of battlefield 4 im hitting 90c, this is with fan at 100%.
I know this card runs hot but i didnt think it would be just as hot as the reference cards..... another problem iv got is when i opened after burner i noticed the volts was set to +13 and the core is down at 977mhz. i thought it was meant to be at 1007mhz???
OSD works nice in Valley but can't get it to work in BF$
done this but still doesn't display ... Probably missing something really obvious![]()
Really liking this card. Nigh on silent compared to what I had to put up with when I had a saph 4850x2![]()
Made no difference, exactly the same - no fan profile page, no access to settings and less than half the monitors available
You need the 64bit version of riva tuner to make it work with bf4. I don't recommend running bf4 in 32bit mode mate. You can download it here. Make sure you uninstall the older version via add remove progs first. Remember its riva tuner to uninstall, not afterburner.
http://archive.sunet.se/pub/games/PC/guru3d/rtss/RTSSSetup600Beta4-Guru3d.rar
gonna change my side panel for the one with fans when i get home, but something else thats bugging me is that its at 977mhz out of the box when its meant to be 1007mhz. is this because i havnt changed the bios switch?
Uninstall old version of afterburner/riva tuner. Restart pc. Install new version of afterburner/rivba tuner. Run it, follow the prompt to restart. Now it should work.
Looks like His 290 aka 'Gold Cube' specimen sports decent finstack/heatpipe array, basically reference pcb and phase design but on the other hand VRM cooling looks bit disappointing (very similar to Asus DCU2).
Uses Hynix vidmem chips
