I know. I was quite shocked by this.![]()
Crazy.
My previous monitor was a BenQ EW2420 which had no blacklight bleed/uniformity issues so this is a bit annoying. Hopefully more people will buy these monitors soon. Thought I had a good deal at getting mine for £152 but £156 for the 24" is a bargain
Looks like we'll need to wait for the reviews of this to tell if it performs similarly to the P2414H then!TFTCentral said:@TFTCentral
Dell U2414H is using different panel to the P2414H, LG.Display LM238WF2-SSA1
That's what I like to hear!Indeed. Got a nice review on the way (as do TFT Central of course). If you like the sound of the P2414H's performance the U2414H won't disappoint you mind.![]()
Just taken delivery of a P2414H - truly epic levels of backlight bleed in the bottom left-hand corner, also right up the left-hand side up to about 1.5 cm in from the edge. This is *not* IPS "white glow," it's the same from whatever angle you look at it, and there's no such problem on the right-hand side when viewed straight on/dead centre. There are also significant issues along the top edge, on the right-hand side.
If it were just a problem with an all-black screen in a darkened room, I could probably live with it, but it's clearly visible even on the blue OcUK forum in daylight, with the backlight turned down to <30%.
Just another datapoint if anyone's interested...
Get that RMA-ed
Oh yes, that's all in hand... I was really just adding a "me too" to the previous reported problems.Get that RMA-ed as above.
I know it will always be pot luck to some extent, but it does seem backlight bleed in the bottom-left corner is far more common with this particular model than it ought to be.
So if you think something is originally backlight bleed but it moves when you rotate the monitor, does this mean it's IPS glow?
It can do. Move 2m back from the screen, keeping your head as central as possible. On a monitor of this size only backlight bleed would remain after doing that.
That would mean that this is the 3rd P2414H that I have and it's still full of backlight bleed.
EDIT - Actually, it's not that bad. There is small amount in the bottom left corner and a small amount in the bottom right corner. There is also some around all edges of the monitor (which was exactly the same as the last unit).
I guess you have no choice but to tolerate it. All monitors appear to be the same! (And I've been through LOTS!)
Yes I know you've been through lots.Being tolerant is the least stressful option in this case. What brightness are you using, incidentally?
