Not as easy as it sounds, greay way to smash into sce b ery
Ok quick Q
I am playing British and have 5 planes 4 2 tier and 1 tier 3 Wellington
If i change the Wellington back to tier 2 so all my planes are tier 2 .
Does that mean i only go in tier 2 matches ?
That is a very good question and the answer is no, whenever a tier is unlocked your now in that tier forever.
So it's best to not use the planes which will unlock the next tier unless your willing to do so.
This is imo a stupid way of doing things as you end up going into tiers with planes from the below tier and it is a lot harder for you to then get the points required to rank them up.
also in the russian research tree there is a plane that goes straight from tier 2 to tier 4/5 completely bypassing tier 3, i'm obviously going to avoid using thta plane once I have unlocked level 2-3 upgrades on it because then I will be in tier 4/5 with tier 2 planes
Started out on this yesterday, what a great game.
I'll start trawling through this thread looking for any tips![]()
What country are you playing as?
First thing to look out for is being careful what you research on your planes. You start off in tier 1 games as you only have tier 1 planes, if you research enough on the tier 1 planes to research a tier 2 plane (as soon as the plane is unlocked for research) you'll wind up in tier 2 games with the bulk of players in T2 planes.
