Guys , i need some help
Msi 290 gaming or Asus 290 dc2
Wich one is the best ?
Has anyone got any setting for Afterburner that they stable overclocked the MSI 290 at?
You should test it yourself to find your own overclock limits, but try 1075/1250 at stock voltage and see how you go. If its stable increase to 1100/1250 and test again.
I just wanted to say thanks for the information in this thread - my gaming edition 290 is being delivered from ocuk today - cant wait till I get home!
I'm hoping that my card comes with hynix memory chips as I believe they are a bit better?
Has anyone recently bought a card from ocuk and had the less desirable elipida chips fitted?
Thanks
Daniel
Hi,
I have done mine, just wanted to get an idea on what other are getting.
When I opened MSI Afterburner the Core Voltage was set to 13, and I right in saying that this is what the card is currently set to run at or is this a software thing?
It was stable at:
Core Voltage +13
Power Limit +50
Clock 1050
Memory Clock 1300
I am still running the standard Bios that the card shipped with and not loaded the Asus version yet. Is that supposed to increase the overclocking capability?
Thanks
Put voltage at +0, that's default. Leave memory at 1250. Put core to 1075, play some games and test.
Roger that, Heaven worked. Going to give BF4 a go now.
Gibbo has done quite a nice write-up (or is in the middle of doing). From that it looks like the MSI one might be best.
http://forums.overclockers.co.uk/showthread.php?t=18575360
These steam sigs that people seem to be using, where would i get me one of those?
Little off topic i know..forgive me.
The sapphire 290 tri-x
But if it's out of the msi or asus, if you read gibbos replies on here it would seem the msi is the one to go for(sapphire better than both, but oos and more expensive).
no problem for this case but my options are msi or asus .gibbo has said numerous times that the asus is rubbish and the one to go for is the msi!!!!
I shall test this card early next week and report back with my findings
