- 11 Mar 2008
- Norn Iron
Well of course it will because it is RNG. In my example just because the rogue gets a coin doesn't mean he will have a card like Defias to play on first turn. I should have said "it can be a huge advantage". I don't think it's game breaking though. But you can get some good early momentum going if you have the right cards.
i agree mate, at the very least it adds an interesting mechanic into the game, ive had games myself where i didnt even get to use the coin before i was smashed, others ive used it for a big nasty, but more often than not its dropping something like faerie dragon or gettin the yeti out on turn 3.
At least with the coin in hand it gives you more options on how to deal with cards the opponent puts out. But again thats all based on the luck of your hand
) so I'd imagine they are a bit lower but rogues I expect are the same. Higher rogues don't tend to play scrubs so much it seems but SI7 is crazy good on turn 2 going second - trade out their 3/2 for your coin+3/3 or you if you want to be extra greedy you could weapon T2 (no attack unless field is sporting x/1), T3 deadly/coin/SI7 and you can combo 5 + backstab in a single turn. It will cost you a lot of cards to do it but in aggro rogue decks this can be a solid lead.
Leaving him a simple hero-power attack to take me out on the next turn
