 - 12 Aug 2005
 - Orpington.
That is a shame, as others have seen benefits. Some have quite a hard time getting it to run but remember it is new, so give it time.
Cheers mate
No its fine, i though it was aimed at me but i took it as a joke![]()
.Ha ha yeah I know the feeling. I planned SLI 780s but it would be overkill and then some. That was then going to be me set for a while but I just thought I'd stay single for a bit. If you buy high end then usually 2 years is about what youc can expect before having to start thinking about dropping settings. Unless up crank the AA right up but I don't personally bother with external AA solutions.
 I want both tbh!I went with the R9 290 as I'd read it was better bang for buck than the 780, annoyingly though I got one of the early Powercolor PCS+ which I think has a faulty GPU as I'm pretty sure mine is from the first batch with the mining issues. Haven't built the new rig to test it yet though so it's still all packaged up, thinking about sending it back and getting a 780, mostly because I want a 1440p 144hz monitor and the Asus G-Sync one coming soon is looking like the best bet, and it'd be a bit silly to have a G-Sync monitor with an AMD card..
I'm not trying to start a G-Sync vs Mantle debate or anything though, honest..I want both tbh!
 - ah wellI know rofls thats why i said whatever hes using because i didn't recognise the name of it.
Did you wake up on the wrong side of bed this morning?![]()
 you never know I am able to run Lightboost on my AMD cards without Nvidia. I fully understand they completely different tech but at this moment dont rule out the hacking community.Not really silly to have Gsync Monitor with AMD card. After all it is my next upgrade just for the 1440p and 144hz
And whats to say it can't be hackedyou never know I am able to run Lightboost on my AMD cards without Nvidia. I fully understand they completely different tech but at this moment dont rule out the hacking community.
For those who already have BandiCam.
Set BF4 to Full Screen Boarder Less, in BandiCam go to Target >> Rectangle On Screen. that will record BF4 in Mantle.
<pic>
Again Set BandiCam to use the AMD encoding app, it will use the GPU instead of the CPU to encode. its much better.
<pic>
I hope you're right, I'm in the middle of a new build at the moment and it'd be nice if I could keep it maxed out for a while!
If game developers take to it (big if, I know), then it'd be silly of them not to really unless they have something better.
It matters because an ability to communicate effectively is better at delivering a point.
Sorry humbug wasn't picking on you only but bad grammar is a bugbear of mine. If you haven't already noticed.
I get raged at on PS4 by children with worse teams than mine in FIFA. Fortunately for me (not for them) they often have bad spelling and grammar so it can make for some funny exchanges.
Another user that can feel the benefits.
"Lastly, the most amazing thing is the perceived smoothness that this API delivers as it evenly renders frames at stable intervals."
Nvidia performance, smoothness is no better in bf4 under dx than amd's. So i would expect Nvidia users to notice the same benefits if mantle was usable on Nv cards.
If i remember correctly it was Nvidia users complaining more on bf4 release about choppy game play. Amd's dx performance seemed to be pretty good from the off where smoothness was concerned.
Dam that's some smooth gameplay, do u know what cared he was using and was it x fire
Computer specs as of Mantle vs DX11.1 vid
Z77 MSI Mpower Mobo
I7 3770k @ 4.895ghz on water
Sapphire R9 290 1075mhz core/1400mhz memory
Sandisk 128gb SSD (OS)
OCZ Revodrive 240gb (1gbps)
32gb Patriot @ 2244mhz
Thats his pc spec. He was running at 1440p.
I'm running a similar system, but I left my sapphire r9 290 Tri x on 1000mhz and 1300mhz memory, and I play on 2550x1080, I get choppy gameplay on mantle 14.1 drivers, what seems to be the problem do u think?
I don't think you have a problem in your setup. It's most likely down to mantle being a really early beta version. Hopefully in future drivers and bf4 patches it will become stable for all users. You could try uninstalling the 14.1 drivers with ddu and reinstalling which has worked for some.
Here's a link to the latest version.
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
roy the boys slipping as usual
lol uncapped . also nice dip to 30 fps in there![]()
Only happened the once when I first loaded the map nothing to put a downer on it lol the rest was superb.
fps was decent but it was more to do with roys comment and titling of bf4 uncapped (it wasn't )it also didn't go close to 200 fps which made it slightly more funnier.
