- 12 Aug 2005
- Orpington.
As I said i'm not going to get involved in the whole Nvidia vs AMD debate
And it's not just this thread
^^ Should not have switched sides.
The grass is always greener here.![]()
This thread isn't about Nvidia vs AMD, it's about the fan oil leak issue on many MSI cards using Twin Frozr style cooler.
Anyways, asked for a RMA few days ago, got a response today saying that the oil leak isn't a fault, they put in too much of it and that it won't harm the system.
A bit disappointing really, with so many fans failing, I expected a better response than this, I shouldn't have to wait until one of the fans fails to RMA it.
I'm just gonna return it under DSR, if I can.
Was that from OCUK or MSI?
It seems to be common with AMD cards, I haven't seen a Nvidia MSI card with the same issue.
http://www.bluegartr.com/threads/118704-GTX-780-Leaking-OilIve noticed a constant rattling noise coming from my case when my fans spin up on my GPU. I figured it was just from vibrations caused by the fans spinning up and that I had a loose screw or wire rattling against the case. I was taking my computer apart to clean everything and then put it back together when I noticed a line of oil directly under my videocard running the length of the motherboard. Then I looked at the fan housing on the card and noticed grease on the fan blades and shrouds of both cards. I emailed MSI but havent received a response yet and after doing some looking around, it seems to be a common issue with these cards
I went into my pc for some dusting and noticed a thin line or liquid under my gpu on the motherboard. I started to freak out, thinking it was water. Upon closer inspection and me touching it, I found it to be some type of oil. I then realized it may be coming from my GPU's heatpipes. I have never encountered this before. My PC seems ot still run as normal, but it can be a forewarning of something bad. Anyone know what this is?
I would do it by phone as I said before.
