- 30 Sep 2005
LOVE THIS THREAD
Obviously I started reading it on page 0
Thats a good analogy.
When counting steps as you walk up the you go up the first step and start counting from 1. You don't stand at the base of the steps, take the first step up and go "2...".
It would be identical except for the ground floor would be labelled as ground floor and the floors upwards of that numbered 1+ accordingly.
Indeed he does. One for the Ground floor, and one for the First floor.
This is one of the dumbest things ive read here since jet plane on a tredmill or what ever that nonsense was...
But that's because you are talking about 2 different things, floors, and stairs.
When you are on a floor, and go up a step, you are on the 1st step, because there are no previous steps.
If you go up 1 floor, you are on the 2nd floor because there was a previous floor (ground/1st).
You are counting apples to oranges, when you should be counting apples and apples.
Would it be identical, or would their be better than yours and you don't want to get shown up?
You're immediately in your first year though. Like you're immediately on the 1st of the building's floors.
You don't have to live in a bungalow to hit the floor when you fall out of bed :/
You have no apples, you walk into a building and are given an apple so now you have 1 apple. You walk up 1 flight of stairs and someone gives you an apple you now have 2 apples, 1 for each floor you visited.
Its relevant, when on the primary entrance to a building you haven't transitioned any vertical space.
When you do you would transition 1 storey arriving at the first floor you encounter beyond the primary level.
There is no point in my creating a diagram to do something I have just as easily explained.
But most beds on normal houses are upstairs - the poster was using an example for if you fell on the ground/1st floor. (not the upstairs floor)
But we have had Floors compared to Levels in a game, and someone counted apples too, and things are still all a muddle![]()
Well that's not true, is it? If you're on the primary entrance to a building, thinking hotels, office blocks, etc. you'd be neither ground or 1st, or 1st or 2nd, depending where in the world your particular primary entrance happened to be located. You'd be twixt the two initial floor spaces.
The first floor beyond the primary level? So the second one you encounter then?
One for the first floor he enters, one for the second floor.
If on every floor of the building you get given an apple and the building has 10 floors then you get 10 apples, not 9 because you get 1 apple on the first floor that you enter.
