Caporegime
- 11 Mar 2005
- Leafy Cheshire
Just read that PSS have a 30k warranty?? I take it this is US only?
Had my Potenza RE002 for over a week now, loving them so far. Great feel to them.
[TW]Fox;25945329 said:It's a warranty not a wear guarantee?
I believe its US only m8, but I've not known any other tyre to last longer that also offers such high levels of grip. Best tyre for sure if you like driving like you stole it from time to time.![]()
Looking at my options and I like the sound of the PSS.
Potentially stupid question, but if you decide to put non-runflats on a car that previously had runflats, would you still pump them up to the same pressure that BMW recommends? I have no way of knowing if cars that had non-runflats spec'd from the factory have different pressures printed on the label inside the driver's door.
In addition, would putting XL tyres on the rear make any difference? I'm pretty sure that all of my previous cars only had XL tyres on the front because of the engine's weight. Admittedly they were all FWD cars.
Not sure to be honest, but 30-35psi is a safe range for none run-flat tyres.
You should always fit four matching tyres to a car, mixing is a bad idea.
Looking for two tyres (front) in 205/40/18, narrowed down to the following:
Falken ZIEX ZE-912 - £80.69
Hankook Ventus S1 evo K107 - £86.59
Dunlop Sport Maxx RT - £113.89
Yokohama S Drive - £118.59
Pirelli P ZERO - £122.09
Michelin Pilot Super Sport - £130.69
The Falken 912 screams budget. Hankook on the other hand seems to be rated highly on PistonHeads and had impressive test results (various 1st and 2nd placings) according to Tyre Reviews.
Obviously the Sport Maxx, P Zero and Super Sport are premium tyres - worth the extra money over the others?
the star performer in that list is the SuperSport its in a different league to those other tyres!
SportAuto said:Unsurprisingly for a dry optimised tyre, the Super Sport only manages an average wet performance with a particular weakness in the aquaplaning tests.
AutoPerformance said:Overall: The Michelin Pilot Super Sport is a good example of how it's extremely difficult to achieve excellent in all areas. Michelin have prioritised dry grip and steering feedback with the Pilot Super Sport, giving the tyre the best dry lap time and handling, at the expense of wet performance and comfort.
If money is limited the Hankook is not bad at all. But if money is no issue the star performer in that list is the SuperSport its in a different league to those other tyres!
Also look for Bridgestone RE002, Yokohama V105, Goodyear Eagle F1AS2 as those are great too!
[TW]Fox;26342499 said:Yea, until it's not a beautiful sunny day.
