Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
It's well within "spec".
I can tell you that the Parnis actually keep better time than the Steinhart actually, so much for Swiss movement eh.
My watch storage needs are fulfilled![]()
For a week at leastMy watch storage needs are fulfilled![]()
I have a question
In just over a year it's going to be my 21st birthday. My folks and family have always wanted for me to get a watch for either my 18th or 21st, and seeing as the former has past it must be for my 21st!
The reason I'm bringing this up so far in advance, is because i'd like to contribute towards the purchase, so that I can get something that I've dreamed of getting.
My first thoughts have been towards a speedmaster, preferable with a leather strap. I've seen a few auto speedmasters go for under 1k, used of course. But, I've read that the Professionals are the pieces to get if you're going speedmaster.
For around 1-1.5k, what would you say that I could be looking at? Preferably I'd like one of the big brands (because i'm shallow and want it).
I also like the look of the Rolex Explorer if that helps; and the Breitling Transocean Chronograph 1461
Thanks chums.
The only difference being the movement - not much then, that's irrelevantI was happy enough going away that for less than £1000 I had a watch that felt and looked every bit as special as they did and the only difference really being that the movement inside was an ETA and not in house.
^^ Dear lord, you are going to have more watches than H Samuels!
If you want you really want is a speedmaster then that is what you should aim at. The hand wound are the most desired by collectors but if you are happy with the auto, what does it matter.I have a question
Thanks chums.
The only difference being the movement - not much then, that's irrelevant![]()
for now........
For a week at least
I'd get another large box ordered ahead of your next watch spree![]()
