is there anyway you could scramble a plane signal?
Well sure if you think it'll help?
E: Beat me to it!
You'll need a hot pan and a rapid stirring motion with a spatula.![]()
That's just crap tbh. The vast majority of landings are carried out manually.
In a lot of cases of landings world wide, the pilot of a commercial liner will not touch the controls when landing unless absolutely necessary (or for the pleasure of landing the craft themselves). Even in severe weather, the ILS will land a plane with no input from a human.
Oh dear.... right back at ya.
Sorry, but that's just incorrect. Like I said, the vast majority of landings are carried out manually. In fact Autoland is rarely used outside minimal visibility conditions except for pilot training and currency.
Source?
Source?
Q: I'm curious about when pilots use the automated systems versus controlling the plane "hands on." Are there times when one is preferable?
A: More than 99 percent of landings are performed manually. There is such a thing as an autoland where you set up an auto approach and, to put it coarsely, the airplane will land "hands off." But I see only a few of those a year—they're only performed in extreme low-visibility conditions, and the airplane, pilot, and airport all have to be certified.
There are a number of conditions on the airfield that must be met in order for an Autoland to be carried out including protection of the ILS signal and having backup generators running. Obviously having these procedures in place slows the operation down and makes it more complicated. Hence the reason why autoland isn't used unless it is required (Low Vis Procedures)
....but a quick search of pprune....
http://www.pprune.org/tech-log/377777-autoland-function-question-pilots.html
Like I said, certain procedures need to be in force on the airport side to allow autolands. From an airport point of view these procedures vastly reduce our capacity and require more resources. Outside of Low Vis Procedures I perhaps see a "Practice" autoland about once a month, and even then, because it's a practice, the pilot is ready to take over at any point should he need to.
Which airport is this at?
