Cheers!
They used to be on the side didn't they?
If this is around £350 I'd probably consider buying it
Nope not last year and you wish!
Cheers!
Cheers!
And looking at the pictures it looks like it may have micro SD, I can see this being my next phone.
I wonder how good the 'Duo Camera' will be. Samsung have managed to achieve the same effect on the S5 with just one camera.
Samsung's implementation like all others needs time to process so that could be a big win for HTC. Presumable their implementation should be instant as it uses 2 camera. I believe all leaks are pointing towards to 5MP shooters.
The HTC One (2014) will measure 146.36 x 70.6 x 9.35, making it a little thicker than its main rivals. Weight is set at 160g.
The screen will indeed be a 5" 1080p unit. The processor is quoted to be a quad-core 2.3 GHz Snapdragon 801, while the battery capacity will be 2,600 mAh. The SIM is said to be of the nano variety (like on the iPhone 5, 5c and 5s, Moto X, etc.) and there will be a microSD card slot to compliment the preloaded 16 GB of storage (10GB of which will b e user available).
There's no world on the camera resolution but the rest of the specs appear the same as last year's model - 1/3.0" size, f/2.0 aperture, 2µm pixel size, etc. suggesting the resolution could again be 4 MP. According to the guide the video capture is still 1080p and not 4K. There will also be a rapid improvement in the front-facing camera which will now pack 5MP sensor.
A Barometer is also said to be on board, but FM Radio is a no-go. You can check out the HTC One 2014 specs page, where we've added all the new info we learned.
So they haven't changed anything other than the MicroSD card slot and the front camera? It's not even out yet and the specs are already meh.
