- 30 Nov 2011
No he's saying he used the highest quality settings, reducing settings increases performance, either Nvidia used the highest settings, in which case the performance is very questionably poor or Nvidia used lower than higher settings making the performance even more questionable.
You're missing the point of as humbug knows his settings and you can't go higher than his settings that is the reference point.
If humbug was using medium settings lets say, then the highest settings may reduce performance so much the numbers could/should be that low, but he used the highest settings. Nvidia's numbers are BS if they used the highest settings, if they used anything lower the numbers are simply BS to a larger degree.
No, he isnt, humbug is saying that his 7870XT on low settings beats a 780ti on unknown probably max settings and cant see why that is a faulty premise
I ran Star Swarm in Mantle on a low setting, that leaves me completely (CPU bound) My GPU is much much weaker than a 780TI and yet with a 4 year old AMD CPU i was able to get 102 FPS. If the much more powerful 780TI is only getting 70 FPS then it must be because its bottlenecked by that 3960K in DX, despite it being so much more powerful than my CPU the performance is 30% less than what i get in Mantle.
With an infentially powerful CPU like the 3960K i would get about 140 FPS in Mantle. add a 290X into the mix i would get about 300 or 350.
The thing with the star swarm demo is that it isalways CPU bound, i never see more than 50% Gpu usage even with deferred contexts enabled, so yes it is entirely plausible that a lower end GPU gets close to the performance of a top tier card that iss running at 50%
Although I never see 100% usage on any core, either in DX or in mantle, so exactly where this supposed bottleneck is occuring is a quandary
I did think how quite Nvidia was and how much limelight AMD was getting, now we know
