Which is arguably better for you anyway
Unless you're form getting it to that position is terrible
No, they were using the bar used for squats, all the shoulder machines were free and they just set a bench up underneath the rack and used the bar.
Sounds like a good way to be doing seated BB press? Lot safer than trying to get your mate to hand you a loaded BB over your head.....
