More core voltage will rid those.![]()
Oops.
What were you doing? ^^^ need to monitor that myself.
Yeah, i had the same thing on the 7870XT at 1215 or higher, more volts usually reduced it.
This is actually what it looks like, just no where near as extreme, its lights like that mostly in Chimney Smoke.
http://www.hardwarecanucks.com/foru.../65702-powercolor-r9-290x-pcs-4gb-review.htmlThe components for this R9 290X’s all digital 7-phase also receive linear heatsinks but that isn’t really needed since they’re built to military grade specs with thermal envelopes of at least 125°C.
AwesomeI've set the fan profile so they run at ~90C so that will do nicely
My 6990's VRMs once hit 123C in Kombustor![]()
i don't think the VRM's were rated for that on them.Your lucky your 6990 didn't Kombusti don't think the VRM's were rated for that on them.
See what i did there.
How do you record average fps when using Mantle?
Type;
perfoverlay.framefilelogenable 1 http://battlelog.battlefield.com/bf4/forum/threadview/2955064773389720087/
Into console when you want to bench, once your done type it into console again changing 1 at the end to 0
Load the resulting .csv into 'BF4 Frame Time Analyzer'
http://www.overclock.net/t/1469627/...e-analyzer-version-4-2-released-major-release
Cheers fellas![]()
) for a restocking fee.Now you can enjoy 200fps at 1080P on Mantle. Just as well that place wanted to charge you £90 (how much?) for a restocking fee.
Yep it was pretty ridiculous, I said no thanks. They're my local store but I don't think I'll buy from them again.
