Sky Updated Epg
14 Jul 2003
Not sure if it's the TV or the Sky plus box but when changing channels it randomly decides one channel will be set at 1080p, the next at 568 or 720. Means the TV is constantly taking time to display a picture.
I've set the sky box to automatic and to each individual resolution but it seems to ignore it anyway and randomly picks on. Only been happening a bit over a week though.
1 May 2003
Bucks
My blue button isn't cycling through favorites? They are still ticked in the options but nothing happens when I press blue? Anyone else having this?
Caporegime
21 Jun 2006
sky HD cannot do 1080p.
set it to 1080i is what is recommended unless you have a really good AVR, then leave it on automatic and let the AVR do the scaling.
for most people though without and AVR 1080i is the best setting.
Caporegime
8 Mar 2007
Surrey
Got this today. Don't like it.
Guide button doesn't go to the guide, and I can't see any way to disable the menu screen like you could previously. Then having the search bar means you have to press back 5 times to get out of the guide and back to TV.
Not a fan at all, its massively counter intuitive and annoying.
4 Feb 2004
Fife, Scotland
I'm also finding this absolutely infuriating. :( Not only that, if you have fat fingers and press the back button just one time too many once back at the TV screen, it chucks you straight back into the Program Guide again. Aaaaaarrgghhh!!!!!! :mad:
26 Sep 2013
West End, Southampton
when in the EPG, is there anyway to bypass pressing the damn back button 4 or 5 times to get back to the tv without the epg displayed on the screen? Whoever thought this was a good idea, must have shared in a battery company or the company that designs the sky controller. So damn annoying.
Caporegime
8 Mar 2007
Surrey
Yeah the Sky button takes you straight back to TV. But its an annoying change.
The TV Guide button not opening the TV Guide is my main infuriating annoyance though! I don't have my Sky box connected to my internet, so 6 of the 8 tiles I'm forced to look at don't even work!
Its gone from a well designed and intuitive interface to something cleared geared towards Sky forcing their new On Demand content in your face! Argh!!!
15 Aug 2005
Glasgow
If you've never connected your box to the internet before, they'll give you a free wireless connector so you can do so. It's worth having it connected, you're missing out on a lot of extra features otherwise.
OP
23 Aug 2004
Just hit the tv guide button twice for the guide from 101 or when watching TV hit the back up button for the guide from the channel you're watching.
Caporegime
8 Mar 2007
Surrey
Keep spamming the back button and you get in an intimate loop :p.
Where can I get a wifi connector for free? Every time I've looked they want to charge existing customers for them.
18 Oct 2002
South Manchester
If you've got the wireless booster that'll work as well. The Ethernet port on the back acts as a bridge. It appears to be the same unit as the original wireless connector with different firmware!
