Take the back heatsink off then, doubt it makes THAT much of a difference.
The cooler is designed to use the back heatsink, you put thermal putty on the back to create contact. This is as it doesn't come with any VRAM or VRM sinks.
Run at x8 you won't much performance if any
I am. There's a bit of a difference in benchmarks, y score on valley is 200~ lower than it should be. However, in real world terms I haven't really noticed anything.
?Or you could buy a proper mobo and a case that supported it while you where at it?
I've got a reference card at stock that insta-black screens when I install 14.4 (works fine with 13.12).
I have seen some suggestions that the 290 needs a 750W PSU. I've got a Corsair TX650 650W PSU with a 52A 12V rail. Does anyone know if it's worth upgrading my psu or would I be wasting my time and money?
My second 290 does 1100 with +0mv
I think i'll use that as my top card when i do my computer.
@the above ^
a stock 290 uses about 250-275w (from the wall) you really don't need a 750w PSU. I'm using a 500w unit for one (will be two shortly)
Edit:
Has anyone seen how much wattage running the fans @100% uses!!
I was idling around 90w @20% fan speed, and 105w @100%![]()
)I don't normally run graphics cards on air (well, not for long) so was shocked at the wattage being used just by a fan...tiny and noisy fan.
Anyway, was using 500w from the wall with max volts applied, 100% fan and clocked @1230/1375. Overvolting adds a fair wack to your power usage![]()
Bit of a meh score - http://www.3dmark.com/3dm11/8346758
Using a little 3770k i'm sending off to my mate in Germany, so was setting up a little overclock for him (4.2, he's not big into overclocking and anything higher will make him paranoid of instability)
My side fan uses 15W at max speedThey push a lot more air, which requires a lot more Horse Power. they could easily use 10+ Watts each flat-out.![]()
Guys I think my 290s are broken. I heard they're supposed to sound like jet engines?
