- 5 Dec 2010
- deep space nine
great gifs
Well I caved and picked up a 34UM65 earlier!! Been setup 30mins and LOVE it so far!! VLC does a cool thing where it can auto crop to 2:35:1 and that's doing me great for TV shows(Movies seem to be fine at native, no black bars)
Glad I went for it, don't need the Pro features of the 95 and this will be tonnes less stressful on the gfx
Will throw up some pics once I have everything tidied and setup properly![]()
Dude even though I have issues with 21:9 games support you have no idea how much I am fighting the buy button impulse for over a week now on that screen![]()
Going to cut part of peeps heads of wit any of those zooms as you do today with may cropped movie rips.
Best to watch it as it is meant to be IMO
Although might be different on the LG due to 1440p v 1080p ?
So European plug and no adapter. Is it OK to use one of those cube like multiplugs and put the two pins in the bottom
http://www.super-electrical.com/multiple-adaptor-british-standard.php
I really love my 16:10 as you know that aspect ratio is so perfect but these 21:9 are just so good lookingI'm more of a media whore so I jumped on it![]()
I really love my 16:10 as you know that aspect ratio is so perfect but these 21:9 are just so good looking![]()
Yes, sold them on as they are useless. The light they give out is so low that you can't really have any other light on in the room. So only useable if you game in the dark.
But then the amBX software is truly dreadful. It looks like it was developed for Windows XP and just about works on Windows 7, often crashing. For the few games that have full support, e.g. Deus Ex, the effect is reasonable. But for anything else you just get some dull grey light.
The final straw for me was Skyrim. With the amBX software loaded it would half the frame rate. After four months the company hadn't fixed it or even responded to the issue. At the time this was probably the biggest game of the year which is a big fail for a gaming peripheral.
whats the size of that Samsung next to the 34 please Lartyconshayo
just looks quite a bit taller than the 34
It's a syncmaster 2693. 27 inch screen.
I know the LG looks great but I also have a 60" Plasma for movies so it does not compare to that size wise anyway. The lack of 21:9 PC gaming support is a PITA as so many games are forced 16:9 support.Love my 30 too tbh, but when this is right it's sooooooooo right. Cinema for one![]()
I won't lie, it's not perfect and their are a couple of small compromises but overall I'm very happy with my decision![]()
(hence the cinema line
