- 2 Jan 2012
- UK.
Generally reckoned that up to 1.35v on core is ok for 24x7 use, depending on temps too of course at load. Think you could push a bit more if you wished to.
Mark
Cheers bud, might try that tomorrow.
Mark
http://www.kitguru.net/components/c...osts-default-clock-rate-of-the-core-i7-4790k/
New rumour, 4.1GHz stock speed now.
For overclockers attending Computex 2014, Intel® is hosting the Intel® OC Challenge for Amateurs alongside a bigger overclocking competition. The Intel® OC Challenge for Amateurs features 8 overclockers competing on air cooling using the new Z97 motherboards and upcoming Haswell K-SKU series CPUs. The registration for this competition is open. All you need to do is submit an XTU result using either the Core i5 4670K or the Core i7 4770K to this competition page. From the selection of submissions we then select the 8 participants at random.
Because of its stock clock, this is going to look pretty good in reviews.
I don't quite believe the 4.1GHZ rumour though.
All I care about is that it launches early June. Please,please,please
Decided in going to wait for Haswell E
It's only a small bump on the current line, nothing to get too excited about coming from a 3770K as you are.
I'm leaning that way too. Just think I'll get more longevity out of it than Z97.
If the 4790K doesn't come in June, What would be the next best processor to go with a z97 mobo ?
from what i gather it will be a big jump on the top end chips!
8 physical non AMD cores!
i can def hold out till Q3..probably!
I'm on my phone boom. What does the video say about 4790k?
