Finally logged in and downloading, 51 minutes to go!
What speed are getting? I'm at 2.1 mb normally it's 4.8 mb
try disable everything in the settings, set to low on others and see how it looks,
you will need to reload the game to be sure changes have taken effect,
if all looks good then turn them on 1 by 1 until you get the problem again then you will know what could be the cause
also DL the 14.6 driver if you haven't already
Any other 144hz users here suffering from stutter on anything above 60hz on this game?
Yay, bought the key from CDKeys which arrived in mins but took ages to log into Uplay (no surprise there) and now downloading at 8MB/s, about 30 mins to get some food before gaming
WTF! Seriously! I pre ordered last week and still haven't got my key from them. The autosystem says outta stock.
hmm, odd, tried 14.6, not much difference, tried a proper uninstall driver then install 14.6, the game seemed faster, smoother, and still does but fraps still reporting relatively awful frame rate. 2x290's should be faster. It could be cpu, but it's a 2500k at 4.6Ghz. It could be that for sure.
Whole thing is just weird, really weird. Also seems like the game is faster sometimes I load it, slower other times, like it's random if it will work well. Very odd game.
I'm a bit concerned that my framerate is tanking but my fans aren't at max speed. What's that indicative of (apart from a bad port)?
