NVIDIA GeForce GTX 880 and GTX 870 to Launch This Q4
6 Feb 2010
Ay? The 480 and the 580 before it were both released at the £400 mark as well.
You can't compare it like that. Price was good across the ranges for the HD5000/GTX400 and HD6000/GTX500 series (partly thanks to the strong exchange rate back then)...for current gen however the flagship Nvidia card launch prices have been air-lifted back to the £550~£600+, thanks to strategic launch of Titan's at high price of £800+.
Man of Honour
OP
21 May 2012
Dalek flagship
Where does it say it is a mid range card in the OP?
When the 600 series came out the 680 wasn't a mid range card, it was Nvidia's flagship.
Last line where it says GK104 replacement.
These cards are not the real deal, all they are is more 28nm that will be optimised a little better than Kepler.
People should not get their hopes up, just look at the specs they don't even compare well to a 780ti. And that 256bit bus is there for a reason, a bit like the original GK104 chips that used it. They did not have the muscle to compete with the Tahiti chips once AMD got the drivers right.
Caporegime
20 May 2007
Surrey
Yes, but we know these aren't going to be the GK110 equivalents, hence I expect they will be launched at similar price points as the 670/680.
Caporegime
20 May 2007
Surrey
With that amount of cuda cores, if the clocks are crazy high, then I can see the 880 being a decent amount faster than a 780Ti.
6 Feb 2010
With that amount of CUDA cores the clocks won't be that high and also the specs in the rest of the card will bottleneck it.
A worthy successor to GK104.
Some people seem to look at only at the CUDA cores count, but ignoring the performance hit from lower ROPs count and narrower bus-size and lower memory bandwidth...
I think best case scenario would be that the GTX880 can "match" the GTX780Ti performance...expecting it to beat the GTX780Ti on while remaining on the 28nm process as well and lower price from Nvidia, I think it's far too over-optimistic.
27 Aug 2008
London
I think it is reasonably safe to assume the GTX880 will outpace the GTX780ti where it matters, gaming benchmarks at 1080/12000p. Just the top model with the full core, all the cut down binned parts below less so.
19 Dec 2010
In reality it was their midrange card sold as the flagship when they worked out it was faster than the 7970. This forced AMD to respond with the 290 & 290X whereby nvidia finally brought out the 780TI which was the original, rumored top tier card.
The way that nvidia played out Kepler was genius in my opinion.
People still saying this? It wasn't like that at all. The GK100 didn't work out, so they had to release the GK104 part as the high end because they had nothing else. They even had to put two GK104's together to make a compute card because they had no GK100 part. It was lucky for Nvidia that AMD did what AMD usually do and completely dropped the ball, releasing the 7970 with very low clocks and high price tag.
And it didn't force AMD to release the 290? lol, unless you can call AMD waiting 1 year and 7 months after the 680 release as been "forced to respond" AMD released the GHz edition of their cards in response to the 680/670.
The GK100 was the original rumoured top tier card. G*110 has always been the naming scheme for second generation cards.
27 Aug 2008
London
GK110: 2880 cores - 550mm^2 + 11% = 3200 cores - 610mm^2
Wow, that's a big die, expensive.
Don't forget space saving from smaller bus and other reorganization/feature cutting. While a different core, the maxwell overview on the 750 described a fair few changes some which improve space efficiency.
This is particularly interesting.
NVIDIA hasn’t given us hard numbers on SMM power efficiency, but for space efficiency a single 128 CUDA core SMM can deliver 90% of the performance of a 192 CUDA core SMX at a much smaller size
http://www.anandtech.com/show/7764/the-nvidia-geforce-gtx-750-ti-and-gtx-750-review-maxwell/3
Caporegime
17 Mar 2012
ARC-L1, Stanton System
The GTX 680 did not force AMD to make the 290, come on :p
28 May 2007
If the gtx680 was Nvidia's mid range then the 7970 was also Amd's. Both had more powerful gaming cores in the pipeline gtx780/ti/Titan/290/290x. The gtx680 was the best Nvidia could produce at the time as was the 7970 on the Amd side.
Man of Honour
OP
21 May 2012
Dalek flagship
The GTX 680 forced AMD to stop pussy footing around and underclocking their Tahiti gpu's.
I think these new NVidia cards are going to have a very hard time on price and performance as they are likely to be in the same part of the market as the 290P, I can only see one winner @28nm and it is not green.
27 Aug 2008
London
Nvidia did have the full fat core ready and shipping around the same time (dates maybe of a little but not much), a fair time before they released it in gaming/consumer form, for use in the titan supercomputer. Guaranteed high margins from professional/scientific markets seems to be the consensus as to why nvidia can go so early for their big core.
Man of Honour
13 Oct 2006
As per a post I made ages ago - there were "leaked" slides that have all but been confirmed as genuine that named the card as the 7870 and the release date pencilled in for the same time as when the 7970 actually came out with no mention in sight of a 7970 at the time. Pretty much both played their top spec mid-range part.
Caporegime
20 May 2007
Surrey
Exactly. People are forgetting this is a whole new architecture. Just look at the 750Ti vs the 650Ti - The 750Ti has less TMU's and less Cuda Cores and only a 100mhz bump on the core and it is still faster ( by a decent margin) than the 650Ti and uses loads less power.
if you translate that over to the 880 then you can expect the same thing. The 880 will be a decent bit faster than the 780 Ti
2 Jan 2012
UK.
In hindsight we can see that's what happened. That's the best they could or were willing to put out at the time and we have been drip fed upgrades on 28nm since..
Saying that their have been some great cards on 28nm, maybe they can squeeze even more out of it? I'm gonna pass on the next wave on 28nm though.
Hopefully this time we don't have to wait so long for the real high end (Fully enabled parts) to surface. Fully enabled 20nm AMD / Nvidia parts are going to be ridiculous. Hope it doesn't take so long..
