Permabanned
- 19 Jul 2012
- Buckinghamshire
I have mine all working great. I haven't oc 'ed at all yet. Will do at some point
Is there any point of getting the K over the non-K version? I'm asking as a 4.4Ghz overclock/boost on the non-K is actually pretty impressive, anyone got their K version to 5Ghz or more yet?
Non K is only 4Ghz boost.
I've had mine booted @5ghz, but wont pass anything
Not tweaked anything though, but i'm sure 5Ghz will be passable with some TLC.
Wprime @ 4.8Ghz. Max temp 67c
TIM is the same we delidded some in Taiwan. The major change is in the power delivery which for me has made no difference to overclocking. Infact my 4770K are better. Maybe average is higher on 4790K but I dont do average.
same codes as the engineering samples
it is,its probably old stock idk,but the 2014 batches will say L4
alsong as it clocks well I wouldn't worry
they were for most of themImagine if the 4770k's max overclocks we see were like 4.3Ghz.
true but it was overhyped imo,5ghz on air is a big ask
you could return it maybe and try and get a 2014 batch?
they were for most of them![]()
