I'm going to own a Powercolor 290 soon![]()
PCS?
Yep!
PCS?
Yep!
It's fantastic I'm very happy with it.
I tried it and if I decide to go crossfire another will fit in my Fractal Arc Midi. But tbh one is doing a perfect job at 1440p with everything I have tried.
boom is selling both his 290x tri-x, good price to http://forums.overclockers.co.uk/showthread.php?p=26484276#post26484276
I should get my reference 290 either tomorrow or Monday!! Cannot wait.
Mine is just a 290 not an x. Tbh I think just the one will do me fine for a while.
I have contacted ocuk via the technical support forum and they think it could be a problem, if not now, possibly in the future.
I was asked if I had sent an email to MSI and I said that I didn't, however, moogley has so if you hear back moogley could you post their reply here so that I can forward it on to the support team at ocuk please?
I think they are going to contact MSI on Monday anyway.
They're great cards. Received mine last week and love it. Playing at 1440p also with 1150/1450 clocks.
if I were you nexus id change your case and get a tri-x also,lovely looking cards
I have now put in a good few hours gaming with the Tri-x and not one problem. I have clocked it up to 1150/1450 and the temp has remained at a max of 71.c after a good hour of BF4 and the same with Titanfall. The card has remained almost silent and is quiter than my case fans running at 800Rpm. I will run the card at stock as tbh I cannot see any difference between stock and over clocked in game.
Performance wise everything was pretty much locked at 60fps at 1440p. I'm not seeing any performance difference over my 780Ti and if anything BF4 with mantle is a bit smoother.
Really cannot recommend this card enough if you are considering a 290.
Only got this case a few weeks ago!
It isn't a bad case, just need better front fans (the antec ones have a super weak static pressure) and better fans for the top (don't think the CFM and static pressure matter as much though for fans exhausting at the top since heat rises). Since removing the noise foam pad and adding the 2x120mm fans at the top, my CPU hasn't gone past 70 degrees, before it was going up to and even over 80.
Yeah I think I will be returning the MSI 290 regardless of what MSI/OCUK say anyway as the sapphire does look like a better card, certainly for temps and noise anyway! (not that I find the MSI to be loud though)
As I am pretty sure that this MSI 290 is throttling as well, which could very well be due to the heat not being conducted to the heatsink because of the lack of contact.
