My Sapphire Tri-x has arrived..
I had a look over the card I couldn't stop myself. First thing is it is massive, second is the build quality is miles better than the MSi. No i'll fitting cooler it's screwed together perfectly.
After installation I powered up and ran some heaven to check all is ok and happily everything works perfect. I did have to check the fans were spinning as this is so quite it's unreal. After 15 mins of heaven my max temp was 64.c which for a 290 is insane. It was also still perfectly quite with just a feint waft if you get close. With the side on the case it's silent.
So finally have a 290 to play with and I'm so far very happy... Well apart from the colour but you cant win them all...
Pics.
