4790k in the house
DPD didn't lose it !!
My take on P95 as a stability tool.
In the old days it was very useful as it gave the memory, CPU integer units and FPU a good workout.
Passing the P95 stress tests meant you could be confident that your PC would be good for running any app.
Nowadays that is no longer true.
P95 now uses AVX code exclusively so it isn't testing the integer and standard FPU maths that it used to.
Very few apps use AVX, virtually no games do.
So it is quite possible to pass P95 on a modern PC and be unstable whilst for example gaming or running flash in a browser.
On a dedicated gaming PC I make sure I use things such as 3dMARK 11 and 13
The Physics tests will crap out on unstable clocks.
I loop things like the res6 bench.
The Cinebench tests should run OK and I will use them as a stability indicator.
R15 will usually barf on unstable CPU's.
The PC's I use for Distributed Computing are tested with P95 very heavily as it is the AVX maths that is used in a lot of the clients.
In some cases the actual P95 libraries themselves for the Prime number crunching projects.
EDIT: The ''new'' TIM is **ite.
Behaviour the same as the old chips, CPU core hot enough to melt lead yet the heatsink is cold
